1 - 2 of 2 Posts
In case any of you want to change your tire or wheel size I have used this site in the past. You just type in your stock size and what ever size you want to get and zero in on a size that will keep the over all diameter the same. The advantage to keeping the over all diameter the same is so that your speedometer is still accurate.
For example if you wanted to put 20s on you could use this to see what size tire you would need to keep your overall diameter correct. I know it says it is for Miata's but that doesn't mater.
Tire size calculator
1 - 2 of 2 Posts
