1 - 11 of 11 Posts
Hi everyone, has anyone tried 245/35/18 on their car? They are very close in size to the stock 225/40/18, just a touch wider and a touch shorter but very close. At the moment my car is lowered 1" and has stock tires and rims. Thanks for any input.
I've put 245/40R18 on a stock height VT before on OEM wheels. If you're lowered 1" the tires you want will clear just fine.
OEM wheels are 18 x 7.5 +49
What wheel width with +38 are you referring to re how it would look?
That size on the OEM 7.5" +49 have very little clearance so I can see a wheel with 9 mm offset difference rubbing some.
1 - 11 of 11 Posts
