1 - 10 of 10 Posts
I have a quick question. Does the adjustment screws on the headlight assembly safe to use with the HID conversion as well?
I am asking because I have not installed it myself as I'm injured and I do not have any idea about what goes inside the assembly and how the screws work. The adjustments are horrible and I need to fix them somehow.
Thanks...
I have HIDs on mine and I did not have to adjust them. It was perfect :)
You are lucky. My right headlight has something like a 20 degrees outside angle shining cars and everything else ahead of me on my right. I have DD low kit as well. I should have looked at it at the shop no matter how professional they looked.
Discussion Starter · #9 ·
OK! It turns out that somehow they screwed up the installation and the L/R adjustment on my headlights do not respond at all. So as a result obviously HID installation has something to do with the adjustments. I can adjust the headlights up and down just fine, and the left and right do not respond one bit. Totally upset!
Take it back to the shop that installed it. If they are stand up, they should correct/repair what need be. That is if they warranty and stand behind their work. Good luck
1 - 10 of 10 Posts
