1 - 7 of 7 Posts
2016 Veloster Turbo
When my car is running and I am driving normally it sometimes smokes like a white greyish tint from the turbo area and it doesn't smoke from my exhaust.
I think it could be that the coolant is leaking and being burned because I reused the copper washers from the coolant lines, and also the coolant tank is now at half after I filled it to full.
It doesn't smoke at idle mostly when I get back from spirited driving.
Thanks for the help I hope it isn't too serious.
btw I recently got my engine replaced not the turbo
Try to locate the source of the smoke by replicating the issue and looking under the hood.
2016 Veloster Turbo
its mainly in the top left area where the turbo is and I looked under the car while it was smoking and It looked like it was from the middle of the turbo
Be sure coolant and not oil. Those gaskets are too cheap to not get new ones. Also making your own gasket is an option.
2016 Veloster Turbo
Discussion Starter #5
right I am going to replace them then and hopefully, it's a small leak, either way, thanks ill let you know if that solves the problem
2016 Veloster Turbo
Discussion Starter #6
Ok, so I replaced the copper crush washers that went to the turbo banjo bolt and no more smoke !!
1 - 7 of 7 Posts
