1 - 5 of 5 Posts
I have a 2014 r spec and was looking into getting a blow off valve and have heard pretty good things about the turbo xs one. I’ve seen several installation videos and none of them mention anything adjustments to the spring. Does anyone know if those are good to go out of the package or will they need the spring adjusted?
They will vary
I’ve never done a bov before. How do you know when and and how far to adjust it
Before changing anything with a BOV you have to be sure the installation is correct. Many install incorrectly and may think the BOV or BOV solenoid are to blame.
If installed correctly the spring should be good to go. Mine is turboxs and has no problems since day one. When tightening dont over due it will strip the support easily.
1 - 5 of 5 Posts
