New 3" CAI design with more fluid bends, bigger diameter piping and more rigid fitment!
Design:
The piping is aluminum and has a 2mm thick wall which means it is very strong. I chose this piping carefully when I was building turbo systems because it wouldn't crush when tightening couplers like some cheaper piping.
The couplers are 3-4 ply silicone which means they are everything and more than you would need for an intake system. They hold up well to heat and clean very easily (unlike some rubber couplers)
The hose clamps are Stainless Steel T-bolt style. This means a few things. They have more clamping pressure than worm groove clamps, because they are wider. They also will not tear into your couplers like worm groove clamps can. They also look much nicer.
The new piping setup on this CAI system provides a smoother, more free flowing route for the air to take. The bigger diameter also ensures the most volume possible can be carried through the piping.
Build:
I am cutting all the piping by hand and cleaning up the edges to ensure there are no burrs that could possibly be sucked into the system. For buyers, you will not need to do anything but remove the stock system and have a couple tools for the install.
I am using a new, cleaner cutting method by going to a shop and cutting them on a nice horizontal band saw to prevent any 'scoring' from the old tool I was using. This provides a much more professional, clean looking cut.
IMPORTANT:
This system does NOT recirculate the bypass valve to the intake, so you will need to leave it disconnected or remove the hose. This will not cause ANY issues with how the car functions or pose any problems. The only difference is that your BPV will now vent to the atmosphere and be a bit louder. It will function as a BOV.
Also, this system does not route the valve breather back into the system as that would introduce blowby/oily substance into the system. You can run a breather filter on your valve cover, vent it to the atmosphere or run a catch can. A catch can will be the most environmentally friendly option. I have mine dumping to the atmosphere right now.
If you really want to route the breather back to the system, I can install a fitting on the CAI/SRI for 10$. The reason I don't include this fitting is to keep the cost down and prevent the chance of blow by gumming up the intake side of the head
I will be selling the standard CAI unit as a CAI only and the user can convert it to an SRI setup if they want. This will still remain the cheapest intake system that you can buy (new anyway) at 140$ shipped including everything.
Here is the SRI setup: (without the CAI extension)
PICTURES TO COME SOON!
Here is the CAI setup: (on jeremy's car)
Here is the FMIC CAI setup on my car: (in 2.75", production will be 3")
What is included:
Pricing will be as follows and include shipping to the lower 48 continental US states:
CAI (with filter) : 145$ shipped
CAI (without filter - you will need to buy your own) : 120$ shipped
FMIC CAI (with filter) : 125$ shipped (Waiting for A/T verification)
Optional breather fitting: 10$ (See above in 'IMPORTANT' section)
If you are interested in buying, my paypal is [email protected].
It will be around 2 weeks from your order date until you can expect it in your hands as I will be building these on an order-by-order basis!
On a scale of: "I don't know what a wrench is-1" to "I can build a motor in my garage-10", I would say this is about a 3 for the CAI and a 2 for the SRI. The SRI is easier because you don't have to remove the bumper at all but the bumper removal/stock intake system removal is very easy.
The only part that some people may not like doing is removing the stock intake system, which requires removal of the bumper and a bunch of bolts/screws. Removing the stock intake system requires a phillips head screwdriver and a 10mm socket.
The entire job for the CAI system should take around one hour or so for someone who knows their way around tools. Maybe an hour and a half for someone doing this type of work for the first time.
This is not a job that I would be afraid to tackle if I was a beginner. I am always around to answer questions!
Design:
Build:
IMPORTANT:
What is included:
