Since the Group Buy is over, I am making a new thread as the V.2 kits are now in stock and available for purchase.
***I will get updated pictures of the V.2 pipe up here momentarily***
Pricing will be as follows:
USA: 520$ shipped
Canada: 580$ shipped
Australia: 700$ shipped
Philippines: 700$ shipped
These kits will always be in stock now, so no waiting on production from the Group Buy. I have 4 of these kits currently in stock with more on the way.
Note: READ THE DIY. After reading the DIY, read every area that says TIGHTEN over and OVER until you tighten everything properly. By not tightening the clamps and bolts enough, you are just begging for leaks. Please be diligent when doing the installation and following the DIY to save you time later.
For the newer guys, these kits have been designed to maintain fluid bends and keep the piping as short as possible.
Why is piping length important? The longer the piping length, the more efficiency you are losing out on. By increasing volume in the piping system, you increase the time it takes to spool the turbo because the turbo has to pump out more volume to keep the system full.
Core size is big but not too big The core size has been increased quite a bit from stock to increase the intercoolers efficiency significantly. However, the intercooler core has not been increased too much as to not serve much more of a purpose and keeping down on the system volume as noted above.
What comes in the kit:
DIY located here: Turbosocks FMIC Install
Payments can be made to: [email protected]
USA: 520$ shipped
- 22"x8"x3.5" bar and plate core Intercooler (616ci)
- 2-2.5" 90 elbow 3 ply silicone couplers
- 1-1.75"-2.5" 45 elbow 3 ply silicone coupler
- 1-2.5" straight 3 ply silicone coupler
- All necessary Stainless Steel T-bolt clamps
- 1/8" thick custom made Intercooler mounting brackets with hardware
- Type S BOV kit with gasket and hardware
- 2.5" custom L-bend for hot charge pipe
- 2.5" cold charge pipe with BPS flange and BOV flange
- extra vacuum line and tee's if you want to run a dedicated BOV line instead of using stock solenoid
