1 - 3 of 3 Posts
I just installed the TurboXS aftermarket BOV and when ever I run over about 3k rpms and downshift I get a loud fluttering from the BOV sound instead of the “whoosh”. I checked all the vac lines an they were all fine, can someone tell me if this normal or not on the 2016 turbos ??
Will happen if there is a leak somewhere, kink in the line, a bad bov solenoid, wrong bov spring, or sticking valve. Turbo xs is known to come with the wrong spring. A forum search will help you find what you need.
1 - 3 of 3 Posts
