1 - 5 of 5 Posts
I have 2015 VT. On the bottom of the washer fluid pump there is a plastic splitter that diverts fluid to the front and rear sprayers. That little plastic splitter cracked and is leaking.
They don't list the splitter as a separate part. It is held on with O-rings. I was able to pull it off fairly easy. It seems like it was meant to be serviceable.
Anybody have any thoughts, ideas? I don't want to spend $97 for a new pump when the pump I have works.
Thank you!
Discussion Starter · #2 ·
I found the whole pump at RockAuto for $36 so I guess it doesn't matter. I'll replace the whole thing.
Thanks!
Reactions: RPW00Mirage
I'm going to claim I was sleepy not stupid, lol. That seems like an excellent fix.
Does anyone know what the function of the cracked part is? Maybe a tiny filter? Maybe some form of distribution regulator? I'll take it apart and report back.
Thank you!
Reactions: Incognito
1 - 5 of 5 Posts
