1 - 5 of 5 Posts
Anyone had any experience with replacing Gen 1 Veloster Turbo Door Moisture Barriers?
you mean the rubber strip? should be pretty easy. are your torn or not sealing?
Referring to the plastic sheet inside the door panel. I believe they use some type of black caulking or dynaflex to stick onto the door.
I was experimenting to see if i can remove a small door ding so i took the panel off and used a hair dryer to melt the dynaflex to peel away the plastic. Just trying to see if i can purchase the plastic sheet so i can redo nicely.
Reactions: misnblu
1 - 5 of 5 Posts
