14581 - 14600 of 14617 Posts
The 12.989 pass I was -.6 psi which was an easy launch. The pass I tried to make later was on 3.5 psi and it spun. I can launch it harder if the brakes will hold it. No worries on the driveline here. If I had a manual car launching on 2 step with a sticky tire then yes I'd be concerned
Interesting, sounds like you can trim off a chunk more with a really dialed in launch on warmed up tires and a better prepped track.
Yes, the car has pulled 1.8 60' in testing and may be able to go into the 1.7's. This will cut a decent amount off the 1/4 mile ET before I add more power into the car. On that particular day I could have added enough power to cut another .2 off the ET and still been safe on the stock turbo. If the car had a better intercooler I could take off maybe another .1 from the ET.
I'm predicting that I can get it to the 12.4-12.6 area on the stock turbo before I have to upgrade anything. At that point this car will get a custom stuffed turbo I've been working on and the head will be studded. Then I'll see if I can make it go into the 11's. But to do that it really has to cut a 1.7 60' or else I'd have to throw stupid power to it to make up for it on the pass.
Oh you know, just doing VT racecar shit.....
Ordered 3 lb battery and a kirkey series 55 17" seat to cut 60 lbs from the car. Those will be in by end of the month. Hopefully I can get the carbon fiber hatch with lexan windows installed as well by then.
WR drag times for the VT here I come!
Seat and seat brackets arrived. Working on fabbing that to mount in the car where it needs to be.
Battery will be here in a few days ready to install.
Custom i take should be done end of the week.
Hopefully I can have all this done and have the hatch ready by 24th and 25th which are my next 1/4 testing days at the track.
Intake air temperatures are a little cool today on 100% methanol on a highway cruise even with the oem intercooler still on the 15 auto VT. Wonder what it'll run at the track with 100% methanol instead of 100% distilled water that ran 12.989 @ 107.85mph.....She sounds good though on the QTP mods! :)
105823
105824
105825
View attachment 105823 View attachment 105824 View attachment 105825
Holy frosty the snow man Batman. 😳
Nice iat's. 👍
Good luck at the next track event. 🙏🏽😎
Nice iat's. 👍
I hope the throttle freezes open and the back of the intake valves are cleaned by ice pellets! ;-)
Will see what the iats are on meth when ambient is in the 40's this weekend! ;-)
On a side note the other day on methanol with the proper nozzle in the car the datalog was indicating the car making 280-290 whp. This would be ~40 whp higher than when the car did 12.989 @ 107.85 mph on water only on a mild tune.
10/24 and 10/25 will be 1/4 mile days! ;-) Been running mid 12's when it hooks in private testing and high 12's when it spins. 110+ mph on many passes. It's going to be interesting when I make this official on the track.....
I'm hoping I'll be running on the 28th and/ or the 30th this month. 🤞
I've already been practicing the tree in my head like the days of old. 😉
Good luck man and hope you break into the 11's. 🙏🏽😎
100% not going 11's on a stock turbo. Stuffed turbo and more mods maybe.....
Wired 2 lithium batteries in parallel for the VT and have them charging on the .8 amp charger. 13 volts, 720 CCA, 32 Ah, 10 amp max charge rate, 6 lbs total. Will cut 27 lbs from current setup.
Also making custom 6 GA grounds in and around the engine bay to update some current wiring and going back and cleaning all the connections as well on the electrical.
MADE A big 3 wire kit as well for the V/VT community as well.
Will have pics of all this over next few days.
Also have a bone stock 15 manual VT a guy is dropping off for a ton of mods. Will post on that over the next few weeks with dyno results and more. ;-)
2013 VT, Manual
Bought some Silverstar Ultra low beam H11B bulbs because both lights burnt out within 24 hours of each other.
Reactions: misnblu
Had a stock 15 manual VT dropped off for maxing out the stock turbo. Guy wants car to be able to run a 12 before I return it. Took a pic of some of the mods I have in for the car right now. More pics details and dyno to come. Some custom mods made for this car will also become available for the VT community.
105831
Also have Big 3 wire upgrade material being delivered tomorrow and making kits up.
