14801 - 14820 of 14859 Posts
Logged a new tune for a customer 2015 manual VT. This tune is safe on the car on 93E10 or any water/meth injection kit setup properly. This was ran on 50/50 water/meth mix using a 270 cc nozzle @ 200 psi.
Boost vs RPM
106302
Ignition timing vs RPM
106303
Throttle position vs RPM
106304
MPH vs RPM
106305
IAT start of pull vs RPM
106306
IAT end of pull vs RPM
106307
Fuel rail pressure vs RPM
106308
Absolute load % vs RPM
106309
ECT vs RPM
106310
AFR vs RPM
106311
any ideas on removing this stud! the previous owner did not tell me until I retrieved it & clearly there isnt much threading for me to work with
Many methods can be used to remove the stud. Suggest to remove all studs and replace with ARP studs.
VT is great Kia is great. Buell time.
106312
weld a nut to it... then heat it and turn it out
Be careful on that 2 wheeler
Yep I cracked 70 in 3 gears quickly on my way to “mexico” pheeewwwwww
Reactions: misnblu
Going to dyno customer 15 manual VT Friday to get gains from muffler delete. Then may play with cam timing and/or full methanol injection vs 50/50. Car did 250 whp on the oem catback so can't wait to see the power changes on the dyno from these things. My prediction is 260-270 whp no problem. :)
Have you tried a stud removal tool? works just like a chuck on drill. works really well and should be able to bit into the stud you have even as stripped as it is. They are only 10-15 bucks
He sold it so not his problem anymore
Got the braided page fuel line from socal garage works (its kdmtuners line I believe), but im scared to install it lol. Seems like a big job. Anyone know of any good install videos on these lines or have any tips to prevent me from screwing it up?
Sent from my SM-G973U1 using Tapatalk
Sxth has an installation how to. Kdm tuners may have an install video not sure. More of a pain getting the oem line out. I cut em back under the car at the fuel tank to speed up the process.
I imagine sxths line is pretty similar, so ill check that out. Thanks.
Only thing different will potentially be the fittings on the end. No biggie.
Broke down and bought a Dragy. Most nowadays do not get track times and only get Dragy times. So why not have Qwik Tyme Performance beat em or the dragstrip and on the Dragy..... :)
Will start posting personal and customer cars Dragy results! :)
Everyone stay posted for Dragy results of various cars that I work on!
106339
Also had customers VT on the dyno today for cam timing tuning. I'd say it responded pretty well! ;-)
106340
