14821 - 14840 of 14860 Posts
2013 VT, Manual
Crack in windshield wash pump motor. Also found a scraper/putty knife in the bumper. Must of picked it up while driving down the road at some point. Also installed a hitch on the car today.
Got headstuds and upgraded DCT... We're in deep boysss!
Just tried this dragy out on a manual VT that does not hook up on this conservative tune and locks me out of shifting. Maybe more runs later tonight.....
106344
106345
106346
Just had a new exhaust put on. Sounds pretty damn good to me.
Remote tuned a 15 manual Veloster Turbo on 93E10 fuel in south FL yesterday that still has the oem intercooler but has a water/meth injection kit to help keep the IAT at bay.
Here are some screenshots of logs showing RPM, boost, ambient temperature, and IAT. Keep in mind that water/meth was OFF on the oem tune and was ON for the tune.
Even with 6+ psi more boost across the curve the IAT's were great! Customer waiting on an upgraded intercooler which will help even more but I'd say it's doing good as-is on this 250+ whp tune!
Oem tune boost curve
106384
Tuned boost curve
106385
Oem tune max boost
106392
Oem tune boost at redline
106387
Tuned max boost
106389
Tuned boost near oem redline
106390
Tuned boost at new redline
106391
Remote tuning a FBO VT on E85 in SO FL. So far revision 1 and 2 looking good. Unreal you can get a cheap fuel from a pump that makes same or more ignition timing across the rpm with 6-7+ psi over stock than the oem tune does on 93E10 fuel.
106400
106401
106402
Worked on a customer's VT all day today.
Fuel line
HKS M45XL plugs
New coils
160 thermostat
20 psi radiator cap
Amsoil coolant
Tune
Only had small fuel leak initially to fix and car would not make proper boost but less than 5% of pulls. Not cool when a car makes 13 psi 20x in a row then all of a sudden 21 psi. Lol!
get a chance to test it? :D
Not just yet.....
After looking it over good I would not consider this much of an intercooler upgrade. It's a half-assed attempt and this is not made for a VT anyway.
Welp. Back to the drawing board.
The core is sufficient but the inlet and outlet tanks are still a restriction themselves. If they make one for a VT with larger inlet/outlet then it would be a good investment.
Good thing I'm having something decent made. :)
like a +300hp kind of restriction or a +400hp restriction?
Not sure how to answer that except to show you this flow vs pressure drop chart for the oem intercooler vs the wagner.
106416
The wagner has 1.5 psi less pressure drop across the core than the oem. But considering the oem has 3.5 psi pressure drop across the core at 250 whp and around 4 psi by 270 whp the wagner will follow suit with less pressure drop but it will still not be pretty by 300 or 400 area.
Second gen VT's need love too! Going to start tuning them here soon! Have 2021 R-Spec tribute local already! :)
106417
I'm not mething around anymore!
Someone has to run a VT on 100% methanol at some point right?
:cool:
106418
Ah. Thanks for helping make sense of that chart!
So it's an improvement but it's going to suffer the same fate the further along you push. In comparison, what does the pressure drop look like in some of the current offerings? Maybe something worth 700$ if you're not chasing big numbers. But it's got hang ups.
