14981 - 15000 of 15015 Posts
Gfb dvx. Another torn stock bov. Also busted the plastic thing out of the riser as suggested.
106758
106759
106760
Reactions: L3g10n and misnblu
Very nice. 😍
So you swapped out the stocker and installed the GFB?
How you liking it so far?
I was thinking of getting the Forged Motorsports blow off valve for my eventual setup?
Any reason why you picked up the GFB over the others?
I'm still in learning mode with all this turdbo stuff. 👍
Yeah I just blow through em lol
I wanted something with adjustment for stiffness and noise, and stock replacement. The damn thing weighs as much as a brick. Very satisfied.
haven’t left the driveway however it’s very loud !
Reactions: misnblu
Still hurting for cash at the moment due to some unforseen expenses, but I was intching to do something for the car, so i plasti dipped my engine cover. Now I've never actually plasti dipped anything before, but I think it came out pretty well despite that.
Sent from my SM-G973U1 using Tapatalk
Good to hear and you'll now be making a statement at all your autocrosses. 😂👍
Looks factory and well done. 😍👍
You dont have to have money to do the little things to make the car better. 🤙
That looks great, I might want to replace my 845 for this.
It would be an upgrade in many ways. If you have a FMIC already then this unit will have more benefit at higher air flow/power levels.
If you make one that will allow me to use my HKS Super SQIV it would be great.
These will be made to be compatible with many different BOV no worries.
I'm so Happy I keep all the parts I remove, I just hope I can save enough money one of the first batch.:unsure::coffee::D
Reactions: misnblu
I will be announcing a special on the first select number of units soon so stay posted for announcements on FB Qwik Tyme Performance and IG @qwiktymeperformance.
Finally got my new wheels and tires. 😍🙌
Konig wheels with tires weighed in at 32lb and the new wheels and tires weighed in at 29lbs. 😈😎
E6AC616B-B701-4FEC-9FBE-1E53EE11D8F7.jpeg 1C2FBE87-6F1E-4B8D-A2E2-F596A96405ED.png 6328C602-341E-4C00-8744-747BE2C1F463.jpeg EEB4B987-D9D8-45C7-A19F-C142002E0714.png
Sent the turbo off to Jet Hot for the 2500degree ceramic coating to help keep the engine bay a bit cooler. 😁
I should have it back mid August.
I'll be doing the down pipe too once I get it and send it off to Jet Hot for the same coating. 👍
Got the 64mm throttlebody installed from QwikTyme and it matches the 25mm tb spacer almost perfectly with only a tiny lip so I'm guessing the spacer measures 63.8mm in diameter which isn't bad. 😉👍
Rear seat delete is done so the trunk is now clear for trailer hitch installation and me planning out the water meth install for the eventual turbo motor.
The car is maxed out on any more upgrades and volumetric efficiency has reached its plateau with the stock tune. She's a quick little car though and keeps the smiles per mile going. 🤙
2013 VT, Manual
Installed the La Prealpina cross bars and a Haul Master roof rack cage.
106809
Reactions: misnblu
Gathering a few parts offered here at Qwik Tyme Performance to ship out to customers!
*OEM gen 1 Veloster Turbo coil set
*Qwik Tyme Performance 3 port TB spacer kit
*OEM BOV solenoid
*AEM V3 water/meth nozzle assembly
*Qwik Tyme Performance water/meth kit × 2 for Veloster Turbo(AEM V3 water/meth kit, AEM solenoid, AEM water/meth filter, ported TB spacer, nozzle sized for the application)
*Qwik Tyme Performance cooling kit(colder thermostat, water wetter, high psi radiator cap)
*Qwik Tyme Performance gen 1 VT hot pipe kit
*Qwik Tyme Performance gen 1 VT SRI.
Keep in mind that the tune and water/meth kits prices are discounted until 7/31/21! PM for any questions or details on anything needed!
106810
Got another VT in the driveway and I see a pattern emerging.....
106811
This FBO auto VT on E85 and VP M1 was hauled in 4 hours for a tune and a good once over by yours truly. Set it around 245-250 whp to be conservative for the roadcourse life the car lives. It will be running at the Roval at Charlotte motor speedway tomorrow so I will datalog and get pics n videos. :)
106823
106824
106825
God I hate waiting on parts. I wanna be fast now!
waiting on a pierburg ebcs. longer vacuum hose. an arm switch so I can turn the meth off when I want.
Also put out a new youtube video.
