1 - 5 of 5 Posts
· Super Moderator
2014 Veloster Turbo Manual
what's low? i think you have it in the right spot. if you don't have enough hose, just grab an inch of fuel line hose from the store in the same size.
· Administrator
Just get some hose to go from the tap to the TB barb or cut the end of the T a little.
2015 VT M/T Tech
Hi, so I tapped in a boost gauge on this line, however I did it a little low, so I need to buy another. It's the line that goes into the throttle body, and has a valve on the middle of it. What is it called?
To directly answer your question, that hose assembly is called "Hose Assy-PCV" (yes, even though it doesn't connect to the PCV at all) and its part number is 29021-2B060
Its reference number in the attached diagram is 28914, with the blue arrow
White Product Organism Font Line
1 - 5 of 5 Posts
