1 - 3 of 3 Posts
I bought the Bc coilovers and I’m wondering what’s a good wheel size to have flush figment and be cambered on stock tire size which is 215/40
Most do 18 x 8.5 +35 on 225/40 without camber. If you do camber you can go with a wider wheel or lower offset. Depends on the camber, the look you want, and the wheels you like.
this thread will help you best for the wheel sizes:
this website is good for comparing wheel sizes/where the will sit in relation to other sizes:
also side note rear camber is difficult to do. if you commit to it then you probably can do wheels that stick out more, but otherwise you'll have your best luck getting something that sits flush with the fender. Ive heard 18x8 +40ish and 18x8.5 +45ish will sit about flush. I wouldn't get anything that pokes any more than those unless you don't plan to slam it on its nuts or camber the rear. hope that helps :)
1 - 3 of 3 Posts
