Where is the blow off valve?
1437 Views 5 Replies 3 Participants Last post by  calypso
Trying to find where the factory blow off valve is on my 2013 VT. I need to Tee into it for the boost gauge. Any info helps and a pic would be great! Thanks. Joe
1 - 6 of 6 Posts
Yep, if you remove your bumper you'll see it. Bumper is very easy to remove, btw.
Just make sure if you try to tee that hose go to the engine side of the solenoid.
Sent from my iPhone using Tapatalk 2
The bumper was super easy to remove. I tapped into the vacuum hose coming off the blow off valve and the gauge works perfectly!!!
1 - 6 of 6 Posts
