shifter base bushings
1 reading
4K views 10 replies 5 participants last post by  rspec2014
#1 ·
Ok got my kit from 6th element pop up the center console. Removed the shift nob. How the hell do I get the reverse lockout to lift off the shift rod... I have the short throw rspec shifter
#5 ·
Get the reverse lock out off of which shifter? For both it all comes off the top. Remove the shifter knob by unscrewing it. Remove the spring and then everything should come out the top. But I'm not sure why you need to remove this unless you're after the shifter boot from the OEM shifter.
I have the Billet Pro Shop shifter and I had to remove an allen screw and the shifter knob and then pull everything off the top. I transferred my stock boot to the new shifter by following a similar concept of removing everything from the top. It wasn't super simple, but it wasn't difficult to do either.
There's instructions for the Veloster at Billet's site. They're all pretty much the same as far as removal and installation.
http://www.billetproshop.com/wp-content/uploads/2014/01/Hyundai-Veloster-Short-Shifter.pdf
#7 ·
For what shifter? I told you in my original post that I have the rspec short throw... I need to remove this to install the shifter base bushings. I remove the knob and undo the console but the reverse lock up is attached to shifter... that is what I am trying to remove...
